I believe this is documented in this NG somewhere... If I remember
correctly, the CUI file is not correctly copied from the CD. Manually copy
the one from the CD.
Larry Bettes
ADT, LDT/CD & C3D
(all 2006 with all SPs installed)
P4 - Dual 3.0 GHz, 1.00 GB RAM
RADEON 9550 AGP - 256 MB
Windows XP Pro, SP 2
wrote in message news:4954053@discussion.autodesk.com...
In the Custom User Interface dialog box, I unloaded the partial menus
"Survey.cui" and "CivilDesign.cui". I then ended my LDD session.
Later, I started a new LDD session. In the Custom User Interface dialog
box, I loaded "Survey.cui" under the "Partial CUI Files" node. When I
clicked on the "Menus" node of the newly loaded "Survey.cui", I could not
see any menus. Same with the "CivilDesign.cui". I was expeciting to see
menus such as "Data Collector" or "Cross Sections", etc.
Thinking I may have corrupted the CUI files, I then copied the original
"CivilDesign.cui" and "Survey.cui" files from the network installation image
folder "..\Program Files\Root\App\UserDataCache\Support" and tried to
partially load them. I still could not see any menus under the "Menus" node
of the partially loaded CUI's.
Am I doing something wrong?
