If not, our friend is in some trouble, because I doubt he had it checked
from the beginning. Jimk, if you have not had your edit history box
checked, I would suggest building a second surface out of your additional
topo (plus a little overlap), and then combining the two together.
"Don Reichle" wrote in message
news:421a497d$1_3@newsprd01...
> Hey Dennis;
> Has the necessity of having that option checked prior to building the
> initial surface been changed in 2005?
> I (along with a number of others here) have been under the impression that
> it needs to be checked on before the initial Build, but I can always learn
> from my mistakes.
> Don Reichle
> "King Of Work-Arounds"
> LDT3 - SP1/CD3 - SP1
> On WIN2K SP4
> Dell 1.6 Ghz P4
> 512MB RAM
> NVIDIA 32MB AGP
> "Dennis Hyman" wrote in message
> news:421a163e$1_2@newsprd01...
>> In your build surface dialog box, you'll note the check-box for "Apply
> Edit
>> History". Update your point group to include your new points, add any
>> faults you may need, and then go to build surface. Make sure you check
> the
>> "Apply Edit History" and then rebuild the surface. All your surface
>> edits
>> should be retained, and the hole should be filled in with the new point
>> information.
>> "jimk" wrote in message
>> news:29697349.1109004825504.JavaMail.jive@jiveforum2.autodesk.com...
>> >I am fairly new to LDT. We have LDT 2005, civil and survey. We went out
> and
>> >shot our points - and then imported them into LDT and created a TIN. We
> now
>> >have to go back out and shoot new points because a land owner has
> declined
>> >us access.
>> > Can I shoot these new points and insert them into my current surface?
>> > Right now I have a hole I need to fill in with these new points but
> don't
>> > want to start over with creating a new surface and tin - can these
> points
>> > just be added in?
>> > Thanks
