Hi Steve,
Bearing in mind that the software is used in non-land based applications to
build TINs representing all sorts of other data, the only generic term can
be TIN. The difficulty with "TIN" is that the terminology is far less
likely to be a part of a user's normal knowledge set than "Surface" or
"DTM".
A couple of examples of other uses are:
Electro-potential at the surface of a re-inforced concrete wall.
Surfaces for jewellery design
Gross rainfall from a rainfall event
Arising from the early software written for Civil/Survey in Australia the
most common terminology (particularly with Surveyors) here is "Contour" as
in:
"Can it create contours?"
"Does it contour?"
"Contourable data"
Laurie Comerford
CADApps
www.cadapps.com.au
"Steve Cannon" wrote in message
news:409fab80$1_1@newsprd01...
> Hi,
> LDD uses the terms 'dtm', 'tin' and 'surface' interchangeably. Actually,
if
> you prefer 'surface', it should be 'Terrain Surface', because we also have
> volume surfaces; composite surfaces; grid surfaces; profile surfaces;
> xsection surfaces, including strip surfaces, existing ground surfaces, and
> subsurfaces; template surfaces, including normal surfaces, subgrade
> surfaces, top surfaces, and datum surfaces; subassembly shoulder surfaces;
> surface slopes; pond surfaces; multiple surfaces on/off that work with a
few
> of the above selected surfaces; then there is the 3d autocad surfaces: 2d
> solid surfaces; 3dface surfaces; 3d object surfaces like pyramid surfaces
> and wedge surfaces; revolved surfaces; tabulated surfaces; ruled surfaces;
> and edge surfaces; lets not forget surface tessellation under shademode
and
> textured surfaces under rendering.
> The terms 'breaklines' and 'faults' are still inter-mixed; and even though
> Autocad changed from 'entities' to 'objects' in R14, LDD still requests
you
> to select 'entities'.
> Search to find an, old but related thread in the LDD Wishes NG, entitled
> 'LDD Vernacular and the User Interface', started June 16, 2001, which
> contains many more examples of the confusing UI. The bottom line is that
we
> will not ever see the inconsistent terminology woven through LDD
addressed.
> Your best hope is for the Civil 3D developers to be aware of the
importance
> of planning for and establishing a clear and consistent UI vocabulary
> throughout that product.
> sc
> "T4" wrote in message news:409f9d15$1_2@newsprd01...
> > on some instances where you can grab surface information, the default
will
> > be (Dtm) and others it will be(Surface). as far as i know, both are
> striving
> > for the same goal, so why not have them both asking for the same prompt.
> > preferrably (Surface) seeing how you are going to a surface.
> > T4
> > LDD 2002
