AutoCAD Land Desktop (Read Only)
Stationing Question for LDD 2009
6 REPLIES 6
smb558
588 Views, 6 Replies
I have a transportation project that has multiple alignments. I am trying to display the stationing in whole numbers instead of going through and deleting the "+00" part of the stationing. For example. I am stationing all whole intervals, so actual Station 1+00 I want to display at just 1, omitting the +00. Is there a way to do this in LDD 2009?
6 REPLIES 6
in reply to: smb558
its just text. do a find/replace and delete all "+00" on the stationing layer
wrote in message news:6392967@discussion.autodesk.com...
in reply to: smb558
Have you looked at Station Display Format under the Aligment pulldown.
smb558
in reply to: smb558
Doug,
I appreciate your suggestion - but I was hoping for a more technical solution. If there is not one - then yes I will just delete the "+00".
smb558
in reply to: smb558
Yes - I have looked here as well. This dialogue box gives me the option to delete/replace the "+" symbol, but not change the formatting of the actual text. Sounds like the only solution is to just delete the text. Thank you for the response.
in reply to: smb558
with stationing sometimes ya just gotta give up and get oldschool.
hint: don't bother tryin to use ttf fonts with width or oblique assignments either.
wrote in message news:6393246@discussion.autodesk.com...
Doug,
the "+00".
in reply to: smb558
Sometimes it's easier to do things "old school" that waste time trying to troubleshoot a program or command. Doug, had a quick and easy way of getting what you want. Wait til you get into Civil3D and these "old school" tips won't work anymore. Not trying to scare you but it sure is a different ball of wax.
