style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"jregier" <what
href="mailto:jregier@dixonhydrogeology.com">jregier@dixonhydrogeology.com>
wrote in message
href="news:f0cf7e3.-1@WebX.maYIadrTaRb">news:f0cf7e3.-1@WebX.maYIadrTaRb...
is the command line equivalent of surface utilities -> lable spot
elevation. I need to extract surface elevation point values for a list of 7000
horizontal points. Where can i find a listing of command line equivalents for
all map and land functions for lisp usage.
Jim
"Bud" <Bud@BudCAD.com> wrote in
message
href="news:CE65958067D85C4375716A2895481C79@in.WebX.maYIadrTaRb">news:CE65958067D85C4375716A28954......
This is what it looks like with command echo
on:
(dt_mnl)(zz_sdsk '(dt_spotlabel))
I'm pretty sure it can't be called from the
command line.
Bud Miller
href="http://www.BudCAD.com">www.BudCAD.com
Legal Descriptions, Parcel,
Point &
Pline Reports, Layer Reports,
Automated Point Groups and
more.
"jregier" <what
wrote in message
7000 horizontal points. Where can i find a listing of command line
equivalents for all map and land functions for lisp usage.
Jim
"jregier" <Thanks
wrote in message
href="news:f0cf7e3.5@WebX.maYIadrTaRb">news:f0cf7e3.5@WebX.maYIadrTaRb...
all. Robert, what is the type and format of variable cur-surf, is it the name
of the terrain surface, or an entity on the surface. I tried the sub-routine
you posted, but it gives a bad-argument type for cur-surf (i tried the name of
the surface terrain "EQUI_01_B2" and variations of entity selection).
Jim
"jregier" <OK,
wrote in message
href="news:f0cf7e3.9@WebX.maYIadrTaRb">news:f0cf7e3.9@WebX.maYIadrTaRb...
fair enough. But i still would like a (better) LISP function that returns the
elevation (or nil if out of bounds) for a point on a surface. Ive loaded the
vl com and reactors, and tried the vlisp help. Using Roberts suggestion as a
starting point,
(vlax-invoke-method
cur_surf
"getelevation"
how do i set the cur_surf object - something similar to (setq cur_surf
(vlax-get-object ???)).
Jim
With help, developed a function to extract an elevation from a surface (or selected surfaces from a list). It's worked fine until C3D2012 and now with the change in format I need to get it working again.
I'm getting error: "Civil 3D API: Triangle is deleted" for points outside the extent of the surface in my sub-function
(setq n
(vlax-invoke cur_surf 'FindElevationAtXY (car pt) (cadr pt)) )
It used to simply return nil without crashing and I could handle the nil value in a number of ways and continue to the next point. I use the function in a number of routines attached directly to Access databases for modelling grids and correcting elevations of fields in a number of large database sets.
Any advice on working around or other vlax function needed to check the xy coordinate to the surface is much appreciated.
