AutoCAD Land Desktop (Read Only)
Spot Elevation Extraction using lisp
17 REPLIES 17
Message 1 of 18
jregier
1901 Views, 17 Replies
what is the command line equivalent of surface utilities -> lable spot elevation. I need to extract surface elevation point values for a list of 7000 horizontal points. Where can i find a listing of command line equivalents for all map and land functions for lisp usage.
Jim
17 REPLIES 17
Message 2 of 18
in reply to: jregier
This is what it looks like with command echo
on:
(dt_mnl)(zz_sdsk '(dt_spotlabel))
I'm pretty sure it can't be called from the command
line.
Bud Miller
href="http://www.BudCAD.com">www.BudCAD.com
Legal Descriptions, Parcel,
Point &
Pline Reports, Layer Reports,
Automated Point Groups and
more.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
what
Jim
Message 3 of 18
From VBA you can use:
RetVal = object.GetElevation(Easting,
Northing)
where "object" is the surface.
Bud Miller
Point &
more.
on:
command line.
Bud Miller
Point &
more.
what
Jim
Message 4 of 18
(vlax-invoke-method
cur_surf
"getelevation"
easting
northing)
where cur_surf is the surface object you wish to query
Steltman Software Solutions
Easy to Use, Productivity Tools for autodesk Land Desktop
web http://www.rsteltman.com/
email support@rsteltman.com
Toll Free 1.866.260.2514
Fax: 1.905.945.6549
"jregier" wrote in message
news:f0cf7e3.-1@WebX.maYIadrTaRb...
> Jim
Message 5 of 18
jregier
Thanks Bud,
now i'm getting upset (not at you). why wouldn't there be a command line equivalent as per map functions. I did find that the function (dt_spotlabel) at the command line requests a leader point, but can't incorporate the function into a routine (would be re-entering lisp during execution). Where do I go from here.
Jim
Message 6 of 18
Jim,
The approach to programming with the ALDD objects is different from that
used historically for normal AutoCAD objects.
Bud's code here is the way to go, rather than trying to use an extract of
the menu line (Note in VBA you can use a SendCommand including the
(dt_spotlabel) components to use the ALDD commands)
You do need more code than indicated here though as you will have to define
the surface variable "object"
Have you looked in the sample code supplied with the software ?
Laurie Comerford
CADApps
www.cadapps.com.au
"Bud" wrote in message
news:F3BDDBF37F76D643F82E2FF93333A54B@in.WebX.maYIadrTaRb...
> RetVal = object.GetElevation(Easting, Northing)
> Bud Miller
> www.BudCAD.com
> Legal Descriptions, Parcel, Point &
> Automated Point Groups and more.
news:CE65958067D85C4375716A2895481C79@in.WebX.maYIadrTaRb...
> This is what it looks like with command echo on:
> I'm pretty sure it can't be called from the command line.
> Bud Miller
> www.BudCAD.com
> Jim
Message 7 of 18
jregier
Thanks all. Robert, what is the type and format of variable cur-surf, is it the name of the terrain surface, or an entity on the surface. I tried the sub-routine you posted, but it gives a bad-argument type for cur-surf (i tried the name of the surface terrain "EQUI_01_B2" and variations of entity selection).
Jim
Message 8 of 18
As Robert said, cur-surf is the current surface
object. If you are just getting started using the ActiveX interface to LDDT, I
would suggest that you start in VBA. There are some great examples in the help
file, and that help file is tightly integrated with the VBA Editor. After you
get comfortable with working with LDDT object, either re code in LISP, or just
make a LISP wrapper to the VBA function. I realize that you probably don't know
VBA, but I bet that if you start with the examples, you will have more
done by this afternoon in VBA than if you worked all week translating
VBA to VisualLISP. Working with Object is much different than sending commands
via LISP. As such it takes a new programming style.
Peter Funk
API Product Manager
Building Industry Division
Autodesk, Inc.
Jim
Message 9 of 18
jregier
Peter
you would bet wrong. while certainly not something commercial, the following routine doe what i need. I wrote and debugged it in less then 20 minutes. The get_elev is not the end result, the function will be dropped into elevation correction routines linked to external databases. I do thank all who have responded, it helped immensly - i have very little time for development, and need to program on the fly.
(defun get_elev ()
(setq e (entlast) d (entget e) elev (cdr (assoc 1 d)))
(command "erase" e "")
(alert (strcat "Elevation is " elev)))
(defun ldd_get_elev ()
(setq pt (getpoint) filenm "c:/acad/temp.scr" fileref (open filenm "w"))
(write-line "(dt_spotlabel)" fileref)
(write-line (strcat (rtos (car pt) 2 2) "," (rtos (cadr pt) 2 2)) fileref)
(write-line " " fileref)
(write-line "(get_elev)" fileref)
(close fileref)
(command "script" "c:/acad/temp.scr"))
Message 10 of 18
If you want to expand into the more
powerful ActiveX interface instead of AutoLISP scripting, then my comment
stands.
Peter Funk
API Product Manager
Autodesk, Inc.
Message 11 of 18
jregier
OK, fair enough. But i still would like a (better) LISP function that returns the elevation (or nil if out of bounds) for a point on a surface. Ive loaded the vl com and reactors, and tried the vlisp help. Using Roberts suggestion as a starting point,
(vlax-invoke-method
cur_surf
"getelevation"
how do i set the cur_surf object - something similar to (setq cur_surf (vlax-get-object ???)).
Jim
Message 12 of 18
OK, Now we're on the same page! You have all the
functionally that you need using the ActiveX interface to the LDDT object model
(including exactly what you are looking for). The help that you are looking for
will not be in the Vlisp help file, it will be in the landauto-reference.chm
file. This help file was written using the VBA syntax, but all the object,
methods and properties are available in Vlisp (once you add a reference to the
type library). If you really want to program in Vlisp, you will have to
translate the examples from VBA to VLisp. For LDDT, the starting point is the
LDDT application object, from there, the current Project, and from the project,
you are off and running. Again, look at the examples in the help file for how it
is done in VBA, and mimic that syntax. However, I really think that you will
make better use of your time if you program in VBA, and then wrap those routines
with LISP calls. Not only will you have a wealth of sample code, the VBA editor
is far better than the VLisp editor. As an added benefit, you will never have to
use DCL again!
Peter Funk
API Product Manager
Autodesk, Inc.
OK,
starting point,
(vlax-invoke-method
 cur_surf
 "getelevation"
Jim
Message 13 of 18
(defun set_up_surfs (/)
;;;This will get the first surface defined!
;;;Note there are no error checkers
(princ
"\nCopyright© Robert Steltman Inc.\twww.rsteltman.com\tToll Free
1.866.260.2514\n")
(vl-load-com)
(setq acadObj (vlax-get-acad-object))
(setq aeccApp (vl-catch-all-apply
'vla-getinterfaceobject
(list acadObj "Aecc.Application")))
(setq aeccProj (vlax-get aeccApp "ActiveProject"))
(setq surfs (vlax-get aeccproj "surfaces"))
(setq cur_surf (vla-item surfs 0)))
Fax: 1.905.945.6549
"Peter Funk - Autodesk, Inc" wrote in message
news:0FB83D508561D0CF1692EE14DBC9C08F@in.WebX.maYIadrTaRb...
> OK, Now we're on the same page! You have all the functionally that you
need using the ActiveX interface to the LDDT object model (including exactly
what you are looking for). The help that you are looking for will not be in
the Vlisp help file, it will be in the landauto-reference.chm file. This
help file was written using the VBA syntax, but all the object, methods and
properties are available in Vlisp (once you add a reference to the type
library). If you really want to program in Vlisp, you will have to translate
the examples from VBA to VLisp. For LDDT, the starting point is the LDDT
how it is done in VBA, and mimic that syntax. However, I really think that
you will make better use of your time if you program in VBA, and then wrap
those routines with LISP calls. Not only will you have a wealth of sample
code, the VBA editor is far better than the VLisp editor. As an added
benefit, you will never have to use DCL again!
> Regards,
> Peter Funk
> API Product Manager
> Autodesk, Inc.
news:f0cf7e3.9@WebX.maYIadrTaRb...
> (vlax-invoke-method
> cur_surf
> "getelevation"
> Jim
Message 14 of 18
Hi Robert,
A VBA equivalent is:
Function GetElev (dVar1 as double, dVar2 as double, sVar as string )
Dim oDTM as AeccSurface ' o for object
Dim dElev as Double
Set ogDTM = AeccApplication.ActiveProject.Surfaces.Item (sVar)
dElev = ogDTM.GetElevation (dVar1, dVar2)
GetElev = dElev ' Return the data to the calling function
End Function
Sub AnyOldCode ()
Dim sDTM as String ' s for string
Dim dEast as Double ' d for double
Dim dNorth as Double
dim dElev as Double
... Other code which will probably establish values for the variables below
sDTM = "Surface1" ' Can be any surface name
dEast = 1000 ' Can be any coordinate
dNorth = 1000 ' Can be any coordinate
dElev = GetElev (dEast, dNorth, sDTM) ' Call the function to get the
value
.... any other code
End Sub
This could be simplified by not using variables to get the data, but in a
real program East, North and sDTM etc would be held in variables:
dElev = AeccApplication.ActiveProject.Surfaces.Item
("Surface1").GetElevation (1000,1000)
It may be habit, but I find the VBA code easier to follow.
As Peter mentioned the sample code for VBA is far more extensive than for
Lisp.
Laurie Comerford
CADApps
www.cadapps.com.au
"Robert Steltman" wrote in message
news:7658CF2408FA41638AAFFEDE46D7D346@in.WebX.maYIadrTaRb...
> (princ
> 1.866.260.2514\n")
> (vl-load-com)
> Fax: 1.905.945.6549
exactly
in
and
translate
> > Regards,
> > Peter Funk
> > API Product Manager
> > Autodesk, Inc.
Roberts
> > (vlax-invoke-method
> > cur_surf
> > "getelevation"
> > Jim
Message 15 of 18
220, 221... whatever it takes.
John Uhden, Cadlantic/formerly CADvantage
[ mailto:juhden@cadlantic.com ]
[ http://www.cadlantic.com ]
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Laurie Comerford" wrote in message news:D23FE6436B15A42A05FBE78484AA58ED@in.WebX.maYIadrTaRb...
> Hi Robert,
> Dim dElev as Double
> End Function
> Sub AnyOldCode ()
> dim dElev as Double
> value
> .... any other code
> End Sub
> Lisp.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> > (princ
> > 1.866.260.2514\n")
> > (vl-load-com)
> > Fax: 1.905.945.6549
> exactly
> in
> and
> translate
> > > Regards,
> > > Peter Funk
> > > API Product Manager
> > > Autodesk, Inc.
> Roberts
> > > (vlax-invoke-method
> > > cur_surf
> > > "getelevation"
> > > Jim
Message 16 of 18
Mr. Mom, right? We quote that line all the time.
"Gotta keep that sense of humor, it's critical."
Bud Miller
"John Uhden" wrote in message
news:AF86836B704CC6E93930028B643E964B@in.WebX.maYIadrTaRb...
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
> > Hi Robert,
> > Dim dElev as Double
> > End Function
> > Sub AnyOldCode ()
> > dim dElev as Double
below
the
> > value
> > .... any other code
> > End Sub
a
for
> > Lisp.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
> > > (princ
> > > 1.866.260.2514\n")
> > > (vl-load-com)
> > > Fax: 1.905.945.6549
message
you
> > exactly
be
> > in
This
methods
> > and
type
> > translate
LDDT
project,
for
that
wrap
sample
> > > > Regards,
> > > > Peter Funk
> > > > API Product Manager
> > > > Autodesk, Inc.
that
surface.
> > Roberts
> > > > (vlax-invoke-method
> > > > cur_surf
> > > > "getelevation"
cur_surf
> > > > Jim
Message 17 of 18
Zactly.
My recent favorite is telling the client they have an "ID Ten T" error... "ID10T"
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
"Bud Miller" wrote in message news:09A9F3CAF567E5CF5399F1C065A0FDF7@in.WebX.maYIadrTaRb...
> Bud Miller
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
> > > Hi Robert,
> > > Dim dElev as Double
> > > End Function
> > > Sub AnyOldCode ()
> > > dim dElev as Double
> below
> the
> > > value
> > > .... any other code
> > > End Sub
> a
> for
> > > Lisp.
> > > Laurie Comerford
> > > CADApps
> > > www.cadapps.com.au
> > > > (princ
> > > > 1.866.260.2514\n")
> > > > (vl-load-com)
> > > > Fax: 1.905.945.6549
> message
> you
> > > exactly
> be
> > > in
> This
> methods
> > > and
> type
> > > translate
> LDDT
> project,
> for
> that
> wrap
> sample
> > > > > Regards,
> > > > > Peter Funk
> > > > > API Product Manager
> > > > > Autodesk, Inc.
> that
> surface.
> > > Roberts
> > > > > (vlax-invoke-method
> > > > > cur_surf
> > > > > "getelevation"
> cur_surf
> > > > > Jim
Message 18 of 18
jregier
With help, developed a function to extract an elevation from a surface (or selected surfaces from a list).  It's worked fine until C3D2012 and now with the change in format I need to get it working again.
I'm getting error: "Civil 3D API: Triangle is deleted" for points outside the extent of the surface in my sub-function
(setq n
   (vlax-invoke cur_surf 'FindElevationAtXY (car pt) (cadr pt))   )
It used to simply return nil without crashing and I could handle the nil value in a number of ways and continue to the next point.  I use the function in a number of routines attached directly to Access databases for modelling grids and correcting elevations of fields in a number of large database sets.
Any advice on working around or other vlax function needed to check the xy coordinate to the surface is much appreciated.
