AutoCAD Land Desktop (Read Only)
Sheet Set Manager
10 REPLIES 10
Message 1 of 11
296 Views, 10 Replies
Sheet Set Manager
I'm using LDD 06. I use SSM thru Land Enabled Map, with fields and the works. ( I plot thru the publish dialog box b/c I read this was preferred.) I noticed though, my sheets are not updated unless I actually open the drawing in Map. In other words the plot does not show my recent revisions done in LDD 06.
And to add to this, when i preview before plotting, the preview is up to date, go figure!
What da ya think? I'm going to see if it does it plotting thru SSM instead of Publish.
10 REPLIES 10
Message 2 of 11
jj3750
Something does not sound right here: the model isn't updated or your fields?
If it is the model then you have a reference problem.
If it is the fields - this has occurred to me if I did some rearranging of
the SS. I have found that removing and reassociating layouts to SS fixes
this malady.
Joe
wrote in message news:5427142@discussion.autodesk.com...
done in LDD 06.
date, go figure!
of Publish.
Message 3 of 11
I've had the issue with the fields not updating (I'll try your fix). So your saying the fact my drawing (linework, model etc) is not updating is another issue. Where i come from we xref two base drawings and then place notes on top of the xrefs.
But why is the problem solved by opening the dwg in Map? And this can't be the fix b/c that defeats the purpose of the SSM.
(By the way, often I have one of the xrefs open in LDD 06 while I'm trying to plot in Map with SSM.)
Thanks for the reply.
Message 4 of 11
..."(By the way, often I have one of the xrefs open in LDD 06 while I'm
trying to plot in Map with SSM.)....." Perhaps you have not saved the xref
prior to opening map. Other than a path issue - not saveing the background
prior to plotting can be the only reason you do not see your xrefs in the
most current state.
Try closing everything before you publish.
Joe
wrote in message news:5427224@discussion.autodesk.com...
Message 5 of 11
Somehow I missed the "Resave all Sheets" when you right click the sheet set name....
Thanks, your suggestions got me on the path to looking for something like "Resave all Sheets", although in the past I had tried plotting with the xrefs closed, and everything saved, and even tried to refresh the SS by closing/reopening, etc.
Thanks again.
Message 6 of 11
HTH
Joe
wrote in message news:5427321@discussion.autodesk.com...
name....
Thanks again.
Message 7 of 11
Ahhh!!
DEMANDLOAD VARIABLE SHOULD PROBABLY BE SET TO 1 . Just stumbled on this ....
Message 8 of 11
yes that would be helpful
wrote in message news:5427886@discussion.autodesk.com...
Ahhh!!
Message 9 of 11
Correction, it should be set to 3.
Message 10 of 11
Trying to se if I'm listening?
Joe
wrote in message news:5428621@discussion.autodesk.com...
Message 11 of 11
They made their point rather well with me Joe.
That SysVar is now part and parcel of my MNL file. 😉
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
CivilSeries-2K4
Intel Xeon 3.2GHz 2GB RAM
XPPro 32bit SP2
Nvidia Quadro NVS 285 256MB
"The only Constant is Change".
"Joe Bouza" wrote in message
news:5429202@discussion.autodesk.com...
Joe
