I am designing a Water Supply Network system using Land Desktop.
I am able to design pipe invert levels quite okay using the FG Center-line tangents functionality. Design levels are imported from FG Vertical Alignment functionality and are showing quite okay in model space. However when i create sheets from the sheet manager, chainage label frames are ok, so too are existing ground level labels frames but the designed invert level lebal only appear on two stations.
Could some one help me with this?
I have attached some sample survey data am using. This data was collected in Neno, Malawi.
