Hi Don,
I've just had a look at the AVI on the web site and it shows Version 4 of
ARD. Also we don't expect users to operate at the same speed as Rad. The
software does that.
The current version is much more automated.
I found I had to Stop the playback and restart it to actually view it.
Regards
Laurie Comerford
www.cadapps.com.au
"Laurie Comerford" wrote in message
news:4165a87b_3@newsprd01...
> Hi Don,
> All our latest AVIs are made with Camtasia which has it own plugin and
which
> is installed with the program.
> When I get to the office, I'll check it out.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> "Don Reichle" wrote in message
> news:41653c57_3@newsprd01...
> > Laurie;
> > I was able to get a copy of your ARD brochure, but each time I click the
> AVI
> > link another window appears and disappears. And yes I am holding down
the
> > Control key to avoid my Pop-up Blocker when I click the link. Do I need
to
> > download an Add-In to IE to be able to view the AVI?
> > "Levels" equals elevations, correct?
> > Don Reichle
> > Hacker Engineering, Inc.
> > "King of Work-Arounds"
> > news:41653a11_2@newsprd01...
> > > Laurie;
> > > Well, since I seem to remember you provide a definition once upon a
> time,
> > > is chainage the regional term for stationing?
> > > I just tried dictionary.com and google to get answers with no success.
> > > Kerb is at least phonetic so that's not a problem.
> > > Thanks for the heads-up on Long Section. I imagine that it's placement
> in
> > > the Menus would make it apparent what it was.
> > > Do you provide a demo version that times-out after a short period so I
> > > could at least get my feet wet?
> > > Don Reichle
> > > news:4162fec8_2@newsprd01...
> > >> Hi Don,
> > >> At the moment it is entirely metric and Australian terminology based.
> > >> Metric:
> > >> This ultimately doesn't matter You put imperial data into the system
> and
> > >> it
> > >> gets processed with exactly the same formulae. The only noticeable
> item
> > >> would be the default section sampling widths of 10 drawing units each
> > >> side
> > >> which would be a bit too narrow if it was feet, and the default
> Template
> > >> which is about 8 drawing units wide overall. The default section
> > >> sampling
> > >> spacing in 10 units also. This can be adjusted and will in due
course.
> > >> Terminology:
> > >> The menu commands are easily changed. The road menu uses "Kerb"
twice,
> > >> and
> > >> uses "Long Section" twice rather than Profile, the Drainage menu uses
> > >> "Long
> > >> Section" once as does the Sewer menu.
> > >> Inside the program and reports, we would use Chainage quite a bit,
but
> > >> it's
> > >> not that hard to change.
> > >> Plotting headers are user configurable.
> > >> Help files would need a large search and replace, and the AVI files
> would
> > >> have to be redone where Chainage has been used. How critical would
the
> > >> use
> > >> of "Chainage" be in the USA ?
> > >> Laurie Comerford
> > >> CADApps
> > >> www.cadapps.com.au
> > >> news:4162a142_3@newsprd01...
> > >>> Laurie;
> > >>> OK, I'll nibble at the bait.
> > >>> Is it Imperial-friendly? You seem like someone who Considers The
> Options
> > >>> from the get-go, so I'm asking if it is only built for Metric?
> > >>> Would us Yanks get tripped up by your regional terms like kerb and
> > >> chainage?
> > >>> Don Reichle
message
> > >>> news:416284f3_2@newsprd01...
> > >>> > Hi Don,
> > >>> > It's not even vaguely tenacious. Compare it with hand drafting
the
> > >>> > sections.
> > >>> > 20 years ago I worked for a firm who basically charged
> $1,500/drawing.
> > >>> > With
> > >>> > Sheet Manager I can churn them out as a finished - checked product
> > >>> > title
> > >>> > block etc.in 15 minutes for cross sections and 30 minutes for
> > >>> > profiles.
> > >>> > Overall, I'm allowing for the odd design change as well. The
actual
> > >>> > generation time is about 10 seconds/sheet, but there is always
> cleanup
> > >>> > drafting and drawing assembly. Allow a little time for the design
> and
> > >> you
> > >>> > can see a profitable business potential.
> > >>> > If it wasn't for Advanced Road Design we would still be building
> Style
> > >>> > Sheets for clients. With ARD, we are realistically looking at
> > >>> > designing
> > >>> > and
> > >>> > plotting things like the roads and drainage for a 200 lot
> subdivision
> > >>> > (including intersections, cul-de-sacs etc.) in a day, and Land
> Desktop
> > >> and
> > >>> > Civil Design, even with a fully setup Sheet Manager is still a
long
> > >>> > way
> > >>> > away
> > >>> > from that level of functionality.
> > >>> > Laurie Comerford
> > >>> > CADApps
> > >>> > www.cadapps.com.au
> > >>> > news:41624dbb_3@newsprd01...
> > >>> >> Laurie;
> > >>> >> I've been called tenacious as a bulldog before (in a positive
way,
> no
> > >>> > less),
> > >>> >> but I think that recitation takes the crown and places it on a
> > >>> >> well-deserving brow. Knowing first-hand what you've gone through
to
> > >> whip
> > >>> >> that portion of the app into something useable, I have only one
> thing
> > >>> >> left
> > >>> >> to say...
> > >>> >> "I bow before my betters!" Well-done, old chap!
> > >>> >> But did the experience leave any interesting scars you'd care to
> > >>> >> share,
> > >>> > like
> > >>> >> Mick Dundee?
> > >>> >> I think SM bears a fair resemblance to a salt-water croc.
> > >>> >> Don Reichle
> > >>> >> "Laurie Comerford"
> wrote
> > >>> >> in
> > >>> >> message news:41623d80$1_3@newsprd01...
> > >>> >> > Hi Don,
> > >>> >> > My personal experience in this area was that it took me about 4
> > >>> >> > hours
> > >>> >> > of
> > >>> >> > experiment (on a very slow computer in Softdesk 7.5) to
> understand
> > >> how
> > >>> > to
> > >>> >> > use Style Sheets and what the limitations of the process were.
> > >>> >> > It took me about a day to learn to modify a profile sheet and
> > >>> >> > understand
> > >>> >> > the
> > >>> >> > nuances of doing so. It took another 12 months to develop a
full
> > >>> >> > kit
> > >>> > for
> > >>> >> > dealing with other aspects of defining style sheets and
> recognising
> > >> the
> > >>> >> > how
> > >>> >> > to deal with the bugs in the style sheet definition process and
> > >> devise
> > >>> >> > a
> > >>> >> > systematic process for getting it right first try.
> > >>> >> > I also had to learn how to create finished drawings where you
> need
> > >>> >> > to
> > >>> >> > assemble several components on one drawing. I'm not a
draftsman
> > >>> >> > and
> > >>> > other
> > >>> >> > users would be much better than me here.
> > >>> >> > It took about 6 weeks elapsed time and perhaps 30 hours to
> totally
> > >>> >> > learn
> > >>> >> > the
> > >>> >> > limitations of the cross section process and to write a lisp
> > >>> >> > program
> > >> to
> > >>> >> > fill
> > >>> >> > in the gaps as they apply to drafting practices in Australia.
Of
> > >> this
> > >>> >> > time
> > >>> >> > period, I would suspect about 10% would apply in the USA as the
> > >>> >> > software
> > >>> >> > is
> > >>> >> > written to reflect USA drafting practices.
> > >>> >> > With a modern computer that learning curve would be reduced to
> less
> > >>> >> > than
> > >>> >> > half. Each time I generated a sheet it took about 10 minutes,
> > >> compared
> > >>> >> > with
> > >>> >> > about 10 seconds now. This certainly destroyed concentration
> and
> > >>> > allowed
> > >>> >> > me to forget what I did last.
> > >>> >> > My understanding of programming has improved and I've
re-written
> > >>> >> > the
> > >>> >> > cross-section process in VBA which took a day or so compared
with
> > >>> > several
> > >>> >> > days for the lisp.
> > >>> >> > It took a couple of years before I found out about
> > >> "cd_nolayercreate",
> > >>> >> > a
> > >>> >> > critical part of defining your own style sheets.
> > >>> >> > During this time period I also wrote about 100 pages of
> > >>> >> > documentation
> > >>> >> > on
> > >>> >> > the
> > >>> >> > various aspects of Sheet Manager. We include this on the
> > >>> >> > Australian
> > >>> >> > Supplementary CD as well as set of local sheets.
> > >>> >> > Regards
> > >>> >> > Laurie Comerford
> > >>> >> > www.cadapps.com.au
> > >>> >> > news:41622507_1@newsprd01...
> > >>> >> >> Jon,
> > >>> >> >> I also am interested in saving myself time, so tkaing the long
> > >>> >> >> learning
> > >>> >> >> curve I've experienced in just the setup phase of Sheet
Manager,
> > >>> >> >> and
> > >>> > the
> > >>> >> >> minefield analogy I alluded to into account I've discarded SM
in
> > >>> >> >> my
> > >>> >> >> search
> > >>> >> >> for Useful Tools to do Useful Work.
> > >>> >> >> If you have invested the necessary time into it to make it
work
> > >>> >> >> for
> > >>> > you,
> > >>> >> > you
> > >>> >> >> have my respect.
> > >>> >> >> May I ask how long it took you to learn its subtle nuances?
I'm
> > >>> >> >> not
> > >>> >> >> trying
> > >>> >> >> to "bait" you here. I am open-minded enough to reconsider
> > >>> >> >> something
> > >>> > once
> > >>> >> >> shown the error of my ways.
> > >>> >> >> Don Reichle
> > >>> >> >> "Jon Luby" wrote in message
> news:1308557.1096812779779.JavaMail.jive@jiveforum2.autodesk.com...
> > >>> >> >> > Don,
> > >>> >> >> > The idea here was to show how to automate a process. For
> folks
> > >> with
> > >>> >> >> > multiple sheet needs, this process will save time. If your
> way
> > >>> > works,
> > >>> >> > I'm
> > >>> >> >> > definitely a proponent of using it.
> > >>> >> >> > As for me, when I have large project work, I prefer to find
a
> > >>> > solution
> > >>> >> >> > that will ultimately save me time; clearly, you don't need
> that
> > >>> >> > solution.
> > >>> >> >> > Jon
