lesheifner,
I am not clear on what your problem is exactly. Do you mean that these
commands work when you install Land Desktop 2005, but then as soon as you
install Civil Design on top of Land Desktop 2005, the commands stop working?
I would like to try to reproduce your problem, but I am not sure what
exactly you have done to get the problem to exhibit itself.
There were many times when people have posted problems in the past, and in
the end it would turn out to be that the user had done some kind of
modification/customization that affected the way the program functions. I
am not saying this is the case for you, but my point is to ask that you
would please post all relevant information, which includes any modifications
that you may have done. Please spell out the exact steps that I should take
to reproduce the errors that you are having. Tell me at which point I
should test the commands to get them to work properly, then tell me at which
point in the install sequence I should test the commands to see that they
will fail.
If you can help me to reproduce the problem, then there is a good chance
that we may be able to help you find a solution.
Jason
Jason Bishop, PE
Engineer / Analyst
ISD Civil Test Development
"lesheifner" wrote in message
news:5434430.1086620845729.JavaMail.jive@jiveforum1.autodesk.com...
> These bunk commands are typed and menu picked. Clicking the actual buttons
and going to the menus don't even work. These aren't custom commands. These
are menu commands that have been in AutoCad since version 12.
> I have now noticed that these commands do work in Land Desktop 2005 but
they do not work in Civil Design 2005.
> It would seem to be in AutoDesk's best interests to have support personel
looking through these forums.
