Hi Grant,
ThisDrawing.Sendcommand "(cr_mnl) " loads the ALD software. It may be
necessary if you haven't carried out an ALD command before running your
program.
ThisDrawing.Sendcommand "(cg:points:import) " should run the Point Import
process.
You should only run this last line as the last command in a function.
(zz_sdsk '(cg:points:import)) effectively packages the Point Import command
into a lisp command LDD which allows you to repeat the command by pressing
enter after running the command from the menu.
Laurie Comerford
CADApps
www.cadapps.com.au
"GDTech" wrote in message
news:D926D5224C19D542EF147D085CA54783@in.WebX.maYIadrTaRb...
> I am looking to this menu macro inside a vba macro... any takers. Thanks
> ^C^C^C^P(cr_mnl)(zz_sdsk '(cg:points:import));LDD
> Grant
