"Laurie Comerford" wrote in message
news:416c3fa3_1@newsprd01...
> Hi Tom,
> Would it be possible for you to tell us what you are trying to do ?
> I just read the whole post and while each of the answers you've received
> appear to answer the point you raised, quite clearly the answer has been
> irrelevant to your real query.
First off, I really appreciate the effort that you and Peter have put into
this thread, Laurie.
I'll try to simplify the question by going through a scenario.
My project scales are 50 horizontal, 10 vertical (units of feet, of course).
I complete a road design, with a profile at 50:10. Now I need to do a wall
profile without any vertical exaggeration, so the settings have to change to
50 horizontal, 50 vertical.
In this situation, if I write code to do anything with the road profile(s),
wouldn't the values be incorrect, due to the changed vertical exaggeration?
I'm planning test this all out, including Peter's suggestion from earlier in
the thread. I'll re-post the results.
Thanks, again.
