Another concept worth considering/trying, also assuming that the same release is used:
Get the other pc up and running with everything installed. Compare the files in the support directory, and all sub-directories. If a file on the old machine is newer than the same file on the new machine copy only that one file. Repeat this process with all files that meet the comparison results. If you go with this method, it may also be worth the extra effort to put these files onto a diskette or CD for future machine upgrades.
Jason Mehlhop
Freelance AutoCAD User & Customizer
jasonmehlhop@adelphia.net
