AutoCAD Land Desktop (Read Only)
Same project names killswitch?
4 REPLIES 4
217 Views, 4 Replies
hello! we have recently upgraded to LDD3 and would like to have the projects
folder name to be "LDD", which is stored under our project #.... this
becomes a problem, because when we want to access one of these projects, it
asks which one to use, but they are in different directories! i would write
more, but my question is, is there a setting to overlook same project names
that are sotred in different folders?? or maybe a default setting of some
sort? thanks....
Steven O
San Antonio, Texas
4 REPLIES 4
Hi Steven,
You can do anything you like with respect to the folders where you store
your data. However, life is much easier if you use the way the software is
designed. For me the thought of naming every project LDD is horrific. The
opportunities it provide for user confusion almost guarantee you will get
messed up project data at some time.
At the absolute minimum you will lose one level of project indexing and
hence take longer to find your data. Particularly if you have large numbers
of projects this will be an issue.
Laurie Comerford
CADApps
www.cadapps.com.au
"STEVE-O" wrote in message
news:4754A164C28E1A6894987D06334728B4@in.WebX.maYIadrTaRb...
projects
it
write
names
> sort? thanks....
> Steven O
> San Antonio, Texas
The original of this message with attached file has been moved to
the Customer Files area
(news://discussion.autodesk.com/autodesk.autocad.customer-files
or http://discussion.autodesk.com/WebX?14@@.ee940b5). Please do
not post files or graphics in product support groups.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: Same project names killswitch?
Date:
Wed, 27 Mar 2002 12:53:57 -0800
"STEVE-O"
Newsgroups:
autodesk.aec.land-desktop.customization
thanks for the reply Laurie! the problem is that there are 2 guys
in the
office who use acad, the rest use microstation... we are moving
our server
to a new one, and the microstation guys and the administrator do
not want a
separate "parent" folder for only LDD projects... we put the
following
folders under our project #: archdwg (for architects drawings),
design (for
all design drawings), letters (for all letters about the
project), and a
couple others.. we want to add LDD to this project folder... how
could this
cause conflicts besides it seeing it as the same name?? we want
the sub
folders to be stored under LDD (align, cogo, cr, dtm, etc....)
and not under
the parent project folder... do u know what im asking?? look at
the attached
picture of our directory structure that we hop for... thanks
again!!!
File: LDD.bmp
SEVE-O:
Replies to topics like this can get wordy (something I hate to do is type
more then I already do) so I'll keep it short.
My company uses a structure almost identical to yours and we too recently
upgraded. We did what you are talking about doing (using a folder called
LDD3 under the project folder). My company is about 100+ with about 40 of
use doing drafting. We used that system for 3 weeks. At that point we
realized how big of a mistake we had made. Better to realize the mistake
and fix it though then live with the burden for the next umpteen years.
Something you should think about. Is there any reason you have to have your
project related stuff (dtm, cogo, align, etc. folders) in the root project
folder? It isn't like Microstation is going to use that information (is it?
I've never used it). You can still put the drawings for that project in
your root project folder. Just the softdesk related stuff (dtm, cogo,
align, etc.) will be somewhere else.
We made a big mistake because we didn't understand the ramifications of
doing it the way we did it (the way you are going to do it). I hope that
you really think about what you are doing before you make the decision to
stick with what your walking into.
If you have any questions, my # is at the bottom, feel free to call me
(that's how strongly I feel about it).
Jeff
Jeff Spannbauer
Civil Engineer II
Cannon Associates
www.cannonassoc.com
805-544-7407
"Drew Burgasser" wrote in message
news:00AEDEFDBF29F689516CD5DD1DAFF01D@in.WebX.maYIadrTaRb...
> STEVE-O:
> You can do what you're doing, but you're not going to get around the fact
> that it's going to ask you which "ldd" project you want to use. So I
guess
> the answer to your first two original questions is "no."
> I would probably change your setup to something like this:
> \28276\
> Land Projects (or LDD)\
> 28276-Phase 1
> 28276-Phase 2
> Land Projects (or LDD) would then become your "project path" as opposed to
> 28276. You can then store your project(s) in Land Projects with a name
> similar to the project name.
> Alternatively, instead of naming the project "ldd", name it "28276-ldd".
But
> I still don't like the fact that the project path is 28276, because I know
> that one of my colleagues would inadvertently choose archdwg, field, or
> letters as their Land Desktop project. There's nothing more frustrating
> then finding a project.dfm in the letters folder. (-:
> Good luck,
> Drew Burgasser
> CAD Masters, Inc.
> www.cadmasters.com
> news:090144A3023565B2FDDC069C8DA474CF@in.WebX.maYIadrTaRb...
> > thanks for the reply Laurie! the problem is that there are 2 guys in the
> > office who use acad, the rest use microstation... we are moving our
server
> > to a new one, and the microstation guys and the administrator do not
want
> a
> > separate "parent" folder for only LDD projects... we put the following
> > folders under our project #: archdwg (for architects drawings), design
> (for
> > all design drawings), letters (for all letters about the project), and a
> > couple others.. we want to add LDD to this project folder... how could
> this
> > cause conflicts besides it seeing it as the same name?? we want the sub
> > folders to be stored under LDD (align, cogo, cr, dtm, etc....) and not
> under
> > the parent project folder... do u know what im asking?? look at the
> attached
> > picture of our directory structure that we hop for... thanks again!!!
> > Steven O
> > San Antonio, Texas
> > "Laurie Comerford" wrote in message
> > news:F57932EDB878A2CEF086B6ED4F179A5B@in.WebX.maYIadrTaRb...
> > > Hi Steven,
store
software
> > is
> > The
> get
and
> > numbers
> > > Laurie Comerford
> > > CADApps
> > > www.cadapps.com.au
> > > projects
this
> projects,
> > > it
would
> > > write
project
> > > names
> > some
> > > > sort? thanks....
> > > > Steven O
> > > > San Antonio, Texas
thank you all for the replies! we havent quite finalized our desicion, but i
think this makes it obvious....
Steven O
San Antonio, Texas
"Jeff Spannbauer" wrote in message
news:8A58D775EE75D2EDE0317754E099B539@in.WebX.maYIadrTaRb...
> SEVE-O:
your
it?
> Jeff
> Jeff Spannbauer
> Civil Engineer II
> Cannon Associates
> www.cannonassoc.com
> 805-544-7407
> > STEVE-O:
fact
> guess
> > \28276\
> > 28276-Phase 1
> > 28276-Phase 2
to
> But
know
> > Good luck,
> > Drew Burgasser
> > CAD Masters, Inc.
> > www.cadmasters.com
the
> server
> want
> > a
> > (for
a
> > this
sub
> > under
> > attached
> > > Steven O
> > > San Antonio, Texas
> > > > Hi Steven,
> store
> software
> > > is
horrific.
> > > The
will
> > get
> and
> > > numbers
> > > > Laurie Comerford
> > > > CADApps
> > > > www.cadapps.com.au
the
> > > > projects
> this
> > projects,
> > > > it
> would
> > > > write
> project
> > > > names
of
> > > some
> > > > > sort? thanks....
> > > > > Steven O
> > > > > San Antonio, Texas
