Show only
Search instead for
Thats work well. Thanks you. I have another question. How can I eleminate ROW lablels where driveways or intersections occur. Without defining another alignment for ROW?
Well i hope there's a faster way....But the only one i know
is to manually remove the ROW between the desired stations with Cross Sections / Design Control / Edit Design Control / Slopes....
Or manually with Cross Sections / View-Edit Sections...
I have a road with a 50' ROW I created an alignment from the
center line. when I do a cross section my ROW lines won't
show up. I've checked the ROW box and set swath 50' left and 50' right.
anything else I need to do
"drafterMTC" wrote in message news:5851191@discussion.autodesk.com...
just offset the centerline of the road 50' both ways(depending on scale factor) and put a label that reads something like R/W above it. its the manual way, but i think more efficient than depending on the program to do it.
