AutoCAD Land Desktop (Read Only)
Road Template Design for grading
5 REPLIES 5
380 Views, 5 Replies
I use civil LDDT version 2002, I am not successful at grading proposed road accurately using road templates. I do make perfect proposed cross-sections with the template, but i can not contour the road properly with or with out curbing. can someone please help me. I have sampled the road anywhere from 1 to 50 feet, i thought maybe this was a problem. I am open for any suggestions. randy
5 REPLIES 5
Hi Randall, 1. how are you generating the surface? 2. when you define your template, to you define the "Top surface" datum? 3. how exactly are they wrong? for now Joe "randall" wrote in message news:23619801.1086704602092.JavaMail.jive@jiveforum2.autodesk.com... > I use civil LDDT version 2002, I am not successful at grading proposed road accurately using road templates. I do make perfect proposed cross-sections with the template, but i can not contour the road properly with or with out curbing. can someone please help me. I have sampled the road anywhere from 1 to 50 feet, i thought maybe this was a problem. I am open for any suggestions. randy
Hi Randall, One other suggestion. Sample at small intervals around curves so that the chords in built model more closely represent the arcs. -- Laurie Comerford CADApps www.cadapps.com.au "Joe bouza" wrote in message news:40c5fb93$1_2@newsprd01... > Hi Randall, > 1. how are you generating the surface? > 2. when you define your template, to you define the "Top surface" datum? > 3. how exactly are they wrong? > > for now > > Joe > "randall" wrote in message > news:23619801.1086704602092.JavaMail.jive@jiveforum2.autodesk.com... > > I use civil LDDT version 2002, I am not successful at grading proposed > road accurately using road templates. I do make perfect proposed > cross-sections with the template, but i can not contour the road properly > with or with out curbing. can someone please help me. I have sampled the > road anywhere from 1 to 50 feet, i thought maybe this was a problem. I am > open for any suggestions. randy > >
joe,
i was sampling the cross-sections at every foot then , then producing points on the cross-sections. then i made the surface from those points. the exact problem is after i generate the surface ( i can't get the software to generate exact grading showing the 7" curb and sidewalks....
randy
laurie,
hi, i sampled the roadway at 1 foot intervals.. read my reply i sent to joe.....
Don't create points - create a grid of 3d faces and add them to your surface (POINT FILES >> AUTOCAD OBJECTS >> 3D FACES). This will usually give you nice clean curbs. Make sure the front face of your curb is not vertical. If you had LDT4, you can create a surface directly from the process sections. -- Karl Fuls PLS Autocad AEC Training and Consulting Autodesk Discussion Group Facilitator randall wrote: > joe, > i was sampling the cross-sections at every foot then , then producing points on the cross-sections. then i made the surface from those points. the exact problem is after i generate the surface ( i can't get the software to generate exact grading showing the 7" curb and sidewalks.... > randy
