AutoCAD Land Desktop (Read Only)
Road Output Option
20 REPLIES 20
Message 1 of 21
CADguy82
578 Views, 20 Replies
Road Output Option
I recently found out about the Road Output command to grade road surfaces through a training. We are currently running LDT 2005. It's supposedly under the Cross Sections Menu, but I can't find it anywhere. Is there some sort of update that I need to install to be able to perform this function?
20 REPLIES 20
Message 21 of 21
in reply to: CADguy82
That's OK - we've known for awhile that anyone can type anything, sometimes
at the worst moment. 🙂
Done it myself, and will do it again.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
"doug k" wrote in message
news:5106573@discussion.autodesk.com...
(redface.jpg)
Oomph, I meant tenth of foot. Easier math thing (normally).
I used to leave the "phantom" portion of contour that would traverse the
curbline as it "jumped" over the curb. The curblines would usually plot
heavy enough to obscure that bit and it would look ok on the plans. But
now, since most of our earth volume work must be done with Agtek, I trim
the contours out between the curb back and face (usually drawn as double
line).
"Don Reichle" wrote in message
news:5106568@discussion.autodesk.com...
I use the agencies standard drawings for my batter distance.
Usually falls into the Inch to Inch-and-a-Half range that way.
