AutoCAD Land Desktop (Read Only)
Road Alignment Template
2 REPLIES 2
231 Views, 2 Replies
I created a road alignment using a template and it worked fine. I tried creating a 2nd road alignment using the same template and their are square cuts instead of slopes. Any ideas?
2 REPLIES 2
Hey sl97v;
My 1st guess is that the 2nd road is deeper than the 1st, so that you may need to increase the width of your existing ground sections so that the slope you have defined will "catch".
Also check to see that the Slope is set properly, and hasn't reverted to Zero. That's something you can set through the attached method highlighted:
Cross Section Control
Thanks for your help!
