AutoCAD Land Desktop (Read Only)
reading 0Xc25d5ec6 exception at 5ac62ch
2 REPLIES 2
traveller180
206 Views, 2 Replies
The lman command does not work and responds with the message:
unhandled exception violation reading reading 0Xc25d5ec6 exception at 5ac62ch.
then shuts down LD. I have purged all of the named layer filters and states from the xref's then restarted LD and get the same problem.
Can anyone help?
thank you in advance
2 REPLIES 2
in reply to: traveller180
Bad news, only one fix that I'm aware of: Reinstall LDD. "traveller180" wrote in message news:2001367.1108742271660.JavaMail.jive@jiveforum1.autodesk.com... > The lman command does not work and responds with the message: > > unhandled exception violation reading reading 0Xc25d5ec6 exception at > 5ac62ch. > > then shuts down LD. I have purged all of the named layer filters and > states from the xref's then restarted LD and get the same problem. > > Can anyone help? > > thank you in advance
Hey Dennis; Did you try a Repair before that Reinstall? -- Don Reichle "King Of Work-Arounds" LDT3 - SP1/CD3 - SP1 On WIN2K SP4 Dell 1.6 Ghz P4 512MB RAM NVIDIA 32MB AGP "Dennis Hyman" wrote in message news:42161e93_2@newsprd01... > Bad news, only one fix that I'm aware of: Reinstall LDD. > > > "traveller180" wrote in message > news:2001367.1108742271660.JavaMail.jive@jiveforum1.autodesk.com... > > The lman command does not work and responds with the message: > > > > unhandled exception violation reading reading 0Xc25d5ec6 exception at > > 5ac62ch. > > > > then shuts down LD. I have purged all of the named layer filters and > > states from the xref's then restarted LD and get the same problem. > > > > Can anyone help? > > > > thank you in advance > >
