AutoCAD Land Desktop (Read Only)
160 Views, 1 Reply
Raster 2004
I have not been able to work with scanned rater images in Civil Series
Raster 2004. I have a TDS-600 that we use to scan-to-file, whish creates a
tiff image that we import into our dwgs.
Error Message - Raster Design was unable to save your file. You may reload
the temporary file, Z:\031017\dwg\AEC12D.tmp, which contains any edit(s) you
may have made. You can then try to save to a different file.
The details specify that the directory is full or does not have write
access.
Our Z: drive has full access for all of our CAD operators.
Please Help,
Bill
*** CONFIDENTIALITY NOTICE ***
This email contains confidential information which is intended only for the
use of the recipient(s) named above. If you are not the intended recipient,
you are hereby notified that forwarding or copying of this email, or the
taking of any action in reliance on its contents, may be strictly
prohibited. If you have received this email in error, please contact James
R. Holley & Associates immediately by reply email and delete this message
from your inbox.
Thank you.
1 REPLY 1
DEG
I have the same problem. I can use "save as" without problems. I went back to RD3, it works fine.
