AutoCAD Land Desktop (Read Only)
Profile and Alignement Issue
2 REPLIES 2
364 Views, 2 Replies
I am hoping that somebody out there can help me out with a problem i'm having with profiles. Basically, after I've created my alignment, and sampled it from the profile menu, when I got to insert the profile, I get this strange error.. I guess its not recognizing the LDD command... (if anybody has any ideas, I would greatly appreciate it) - I'm using LDD 2008. thx.
Command:
Alignment Name: STM-A Number: 22 Descr: 6-23-08 KAR
Starting Station: -25.00 Ending Station: 450.18
Select starting point:
Delete existing profile layers [Yes/No] Yes: Y
Deleting profile block STM-A ...done!
Erasing entities on layer STM-A-TXT-PROF-STAT ...
Erasing entities on layer STM-A-CT-PROF-VGRID ...
Erasing entities on layer STM-A-CT-PROF-BASE ...
Erasing entities on layer STM-A-CT-PROF-EGC ...
Erasing entities on layer STM-A-CT-PROF-EGL ...
Erasing entities on layer STM-A-CT-PROF-EGR ...
Erasing entities on layer STM-A-CT-PROF-FGC ...
Erasing entities on layer STM-A-CT-PROF-GRID ...
Erasing entities on layer STM-A-TXT-PROF-GRID ...
Erasing entities on layer STM-A-TXT-PROF-CNTR ...
Erasing entities on layer STM-A-TXT-PROF-LT ...
Erasing entities on layer STM-A-TXT-PROF-RT ...
Erasing entities on layer STM-A-CT-PROF-DGL ...
Erasing entities on layer STM-A-CT-PROF-DGR ...
Erasing entities on layer STM-A-TXT-PROF-FGC ...
Erasing entities on layer STM-A-CT-PROF-FGL1 ...
Erasing entities on layer STM-A-CT-PROF-FGL2 ...
Erasing entities on layer STM-A-CT-PROF-FGL3 ...
Erasing entities on layer STM-A-CT-PROF-FGL4 ...
Erasing entities on layer STM-A-CT-PROF-FGR1 ...
Erasing entities on layer STM-A-CT-PROF-FGR2 ...
Erasing entities on layer STM-A-CT-PROF-FGR3 ...
Erasing entities on layer STM-A-CT-PROF-FGR4 ...
Erasing entities on layer STM-A-CT-PROF-FGL5 ...
Erasing entities on layer STM-A-CT-PROF-FGL6 ...
Erasing entities on layer STM-A-CT-PROF-FGL7 ...
Erasing entities on layer STM-A-CT-PROF-FGL8 ...
Erasing entities on layer STM-A-CT-PROF-FGR5 ...
Erasing entities on layer STM-A-CT-PROF-FGR6 ...
Erasing entities on layer STM-A-CT-PROF-FGR7 ...
Erasing entities on layer STM-A-CT-PROF-FGR8 ...
No entities found on selected layers!
Loading AECC Base...
Loading AECC Land...
Loading AECC Subentity Selection...*Invalid*
28.797696
Unknown command "LDD". Press F1 for help.
28.797696
0.000000
Unknown command "805.00". Press F1 for help.
*Invalid*
Unknown command "STM-A". Press F1 for help.
Unknown command "STM-A-TXT-PROF-STAT". Press F1 for help.
Unknown command "STM-A-CT-PROF-VGRID". Press F1 for help.
Unknown command "STM-A-TXT-PROF-CNTR". Press F1 for help.
Unknown command "STM-A-TXT-PROF-FGC". Press F1 for help.
Unknown command "STM-A-CT-PROF-EGC". Press F1 for help.
Unknown command "STM-A-CT-PROF-EGL". Press F1 for help.
Unknown command "STM-A-CT-PROF-EGR". Press F1 for help.
Unknown command "STM-A-CT-PROF-FGC". Press F1 for help.
Unknown command "STM-A-CT-PROF-GRID". Press F1 for help.
Unknown command "STM-A-TXT-PROF-GRID". Press F1 for help.
1
2
50.000000
50.000000
50.000000
2.166450E+006
1.239450E+006
805.000000
-25.000000
450.184315
Unknown command "LEFT". Press F1 for help.
Unknown command "STM-A-TXT-PROF-LT". Press F1 for help.
Unknown command "STM-A-TXT-PROF-RT". Press F1 for help.
Unknown command "STM-A-CT-PROF-DGL". Press F1 for help.
Unknown command "STM-A-CT-PROF-DGR". Press F1 for help.
2 REPLIES 2
I think you may have deleted profiles using the AutoCAD Erase command
instead of using the profile menu commands.
Turn on attdisp & see if you find little tiny blocks that define the
profiles. If so either erase them and redraw your profiles.
I don't know how much work you have in this dwg but it may be easier just to
start a new dwg & draw the defined profiles.
If this is the case, next time when you need to get rid of a profile
definition, go to the Profile menu, Choose Create Profile and then Undefine
Profile to get them out of the drawing.
If this is not the case, please disregard this babble. 🙂
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message
news:5964743@discussion.autodesk.com...
thx.
Command:
28.797696
28.797696
0.000000
*Invalid*
1
2
50.000000
50.000000
50.000000
2.166450E+006
1.239450E+006
805.000000
-25.000000
450.184315
Thanks for the help John, however, the problem is that I can't even draw the profiles to begin with. The erase that you see on the command line that i pasted, is what the program does before inserting the new or updated profile. I'm not really sure what its doing, but I will try to recreate the project folder. thanks.
