AutoCAD Land Desktop (Read Only)
Problems with points converted from Civil 3D to Land Desktop
1 REPLY 1
645 Views, 1 Reply
I am working in a Civil 3D 2009 Land Desktop Companion drawing that was down-converted from a Civil 3D 2013 using Trueview 2013. The points appear fine in my Land Dekstop 2009 drawing but the problem I'm having is that I cannot Insert/Remove Points from Drawing NOR can I simply erase the points using the regular erase command.
I would like to just get rid of the points from the drawing and re-import the points from the original TXT file. I've tried exploding them, which doesn't work either.
Any suggestions?
1 REPLY 1
AllenJessup
Have you tried multiple explodes? The points may have come in as multiply nested blocks. I'm not sure why you can't erase them though. Try unlocking all the layers in the drawing.
If none of that works. Can you post the drawing? I don't have LDD anymore. But I can open it in basic AutoCAD 2014 and take a look.
Allen
Allen Jessup
CAD Manager - Designer
