I've been having an issue with the command line. When I type commands, like "PL" for example, then hit the spacebar, AutoCAD will start the polyline command and ask me for a starting point. But it will put an "L" in the command line and I can't do anything until I delete the "L".
Better explained:
Command:
Type {PL}
Press {spacebar}
Resluting command line looks like this:
Command
PLINE
Specify Start Point:L
It happens with more than just polylines and the L key. I thought the keyboard was sticking, so I replaced it, and then replaced it with a thrid keyboard and the problem still happened. I doubt it's a software issue, but I only have the problem with Cad.
Any thoughts?
Any thoughts
I've been having an issue with the command line. When I type commands, like "Z" AutoCAD will start the Y command. What is tha problem
Any thoughts?
