I'm wondering if anyone else has ran into this issue. I'm running LDT 2009 Companion and get an error when I try to attach an image through the "Autodesk FDO Provider for Raster" that just says "There was a problem adding data to Map." This function worked fine up until I upgraded to Win7 64bit, but I need to figure out a solution pretty quick.
OK, so it turns out that if you're having this problem the solution is to run LDT as an administrator. Easiest way to do this is just to turn that option on in the shortcut properties.
