AutoCAD Land Desktop (Read Only)
points in file but not in database
3 REPLIES 3
three_dogs
387 Views, 3 Replies
I've added points to a drawing through LDD but now the database is not recognizing them. I select the points and there are 835 Civil Point Objects but when I try to add them to a point group LDD won't recognize them at all. I need to get these points in a point group to make a surface and I don't want to go back and re-insert them all again manually!!!! Please help!
3 REPLIES 3
auzzie2776
in reply to: three_dogs
under points --->check points----->modify project---> check the add unregistered points to database. and you should be good to go
three_dogs
AWESOME!!! After a couple tries I finally got it using this! Thanks so much! You saved me a few hours of work!
auzzie2776
no worries mate
