No one replies because there is no efficient way to bring this data in. You can use the Data Connection with MySQL and connect it with an access database of the parsed points with attributes, but it's clunky and an unreasonable way to use the information. The attribute data needs to be seen in a similar way to shapefile node attributes (in the properties dialog), while preserving the AEC point data in the project database.
