see attached:
do you mean you want it to look like the upper one, NOT the lower one?
if so, i believe the answer is to add/edit vertices to get the look you
want. It might have been a setting once, but probably no longer. hopefully
someone will correct me if im wrong.
wrote in message news:5423352@discussion.autodesk.com...
I'm using LDD 2004 - Can someone plz remind me of the command to modify how
a PLINE displays each line when it comes to an intersection. I've opened an
old dwg and in this dwg the pline intersections are not fillet-ed (?) to be
a solid continual line, instead one line is cut off square and the other is
cut off diagonally, and since the pline width is 3', the diagonal edge
extends WAY beyond where I want it.
THX
