Sounds like your dimassoc variable is turned on. If you draw a leader to a
line, and then move the line, the leader arrow will stay with the line. I
had that happen to me too, and felt much the same.
If you do not wish for your leaders to update, change the dimassoc variable
to 1.
"Howard Kaplan" wrote in message
news:4214b75a_1@newsprd01...
>I could be going crazy.
> I'm working with profiles and I'm labeling Proposed Drain Pipe in profile.
> So, I have the profile in Model and I'm labeling the inverts in Paper
> space.
> I had to move the manhole about 20 feet. When I went back to paper to move
> the invert labels the text was in the original location and the weird
> thing
> was that the arrow heads on the leaders followed the manhole as if they
> where associated to the actual invert in the profile.
> Hopefully you understand what is going on. Has anyone seen this before and
> why would it be doing this.
> Thanks,
> Howard Kaplan
> Sidney B. Bowne & Son
> 235 E. Jericho Turnpike
> Mineola, NY 11501
> Phone: (516)746-2350
> Fax: (516)747-1396
> www.bownegroup.com
> hkaplan@bownegroup.com
