Just a tip, you can add a dimension style pulldown using the same method.
Works great.
Bud Miller
www.BudCAD.com
AutoCAD & LDD apps and more
"James Wedding, E.I.T." wrote in message
news:4D4E9FD0F5119DF0353412267BFDFCBA@in.WebX.maYIadrTaRb...
> Proceed at your own risk:
> 1. Go to your LDD\Support directory (or wharever LDD is stored then
support)
> 2. Copy the Acad.mns file and paste it directly back in (backup copy).
> 3. Open the Acad.mns file with notepad
> 4. Search for **TB_OBJECT_PROPERTIES
> 5. You should see the following a couple lines below it:
> ID_Layer [_Button("Layers", "ICON_16_LAYERS",
> "ICON_16_LAYERS")]'_layer
> [_Control(_Layer)]
> [_Control(_Color)]
> [_Control(_Linetype)]
> [_Control(_Lineweight)]
> [_Control(_PlotStyle)]
> 6. Delete the portions you don't need to that you have only
> [_Control(_Layer)]
> 7. Save and close.
> 8. Run LDD and you should be there. If it doesn't work, exit out, erase
the
> modified file and put the copy back in place.
> HTH--
> IT Manager
> Jones & Boyd, Inc.
> Dallas, Texas
> jwedding@NOSPAMjones-boyd.com
> Remove NOSPAM from e-mail for reply.
