Sometimes this work... but sometimes it doesn't... Cross Section pulldown/Ditch Transition/Edit Profile Alignment... select the profile (ie, center, left, right) The report appears, but in a different format then you are used to... select print to file... find the .txt file where ever you saved it to.. and print via wordpad... That's the only thing I have come up with to by pass this wonderful program not giving my the www version of the report... Hope that helps
