Hi Lee,
I've seen things similar to this when the alignment had duplicate vertices.
Make sure your alignment is clean. Duplicate verticies will show two PI's
with identical stations.
Brian
"alr4" wrote in message
news:28515592.1093448002757.JavaMail.jive@jiveforum1.autodesk.com...
> I have spent quite some time trying to correct the "no vertical exists"
for half of a roadway. I have created the FG centerline, redefined the
profile, along with many other functions to attempt to correct, but I have
not been successful. The vertical alignment is on the correct finished
ground layer and all the labeling functions work properly inside the profile
for the respective vertical alignment and the alignment appears correctly in
the vertical curve editor. How can I correct?
> Thanks,
> Lee Robertson
