Go to point settings and click off pnt and desc and leave elev on. Pick the
"X" symbol you want and even a rotation angle if needed. Set your points on
your surface. I usually make sure I use a specified range of points to
manage easily if needed, like 2000 to 3000 or whatever. You could go back to
the old softdesk point, in which you will have NO graphic ability to choose
those points, only by number or preset group
Sbaumer
"Laurie Comerford" wrote in message
news:42164c61$1_2@newsprd01...
> Hi,
> You can do anything to display a point. You are able to define your own
> Point Label style which can include a block to represent the "X" and
include
> a piece of text for the height value.
> You can change the settings of a Point Object so that is shows an "X" at
the
> point and just the height. In both cases you can control text details -
> precision, font, layer and text height. With the text you can add
suffixes
> and prefixes to the definition.
> I would suggest you do the Tutorial on Point display which you can find in
> the Help menu.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> "dbaxter" wrote in message
> news:25572903.1108753213971.JavaMail.jive@jiveforum2.autodesk.com...
> > I am new to LDD3 for contouring and placing spot elevations. Can I place
a
> spot elevation with an "X" rather then a leader? I have looked at settings
> but no help.
