AutoCAD Land Desktop (Read Only)
Need to create multiple block attributes dependent on one prompt
2 REPLIES 2
bcsurvey
1815 Views, 2 Replies
Seems like a simple operation, but I can't find it in the help section:
I'm somewhat familiar with block attribute definitions, but I can't seem to find a way to add attributes that are dependent on an EXISTING attribute, so that I don't have as many prompts. When I copy the attribute in the block editor, it adds an entry to the attribute list for that block and thus another prompt upon inserting the block. For example, I'd like to end up with a block that displays 5 variable attributes, but for which only 3 prompts are required, since the remaining 2 are dependent on one of the three prompts. Can this be done?
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
2 REPLIES 2
in reply to: bcsurvey
See this post, I think they were trying to do the same thing you are trying to do. Hope this helps you.
http://discussion.autodesk.com/forums/thread.jspa?threadID=771475&tstart=250
bcsurvey
Yes, 3 and a half years later, but the link above doesn't work anymore.  The gurus at Autodesk in a frenzy to continually change the forum sites are earning their weight in . . . something.
Civil 3D 2019 (6.1)
32GB RAM
NVIDIA RTX A2000
