Hey Molly;
I will answer those questions with just one question in return:
How many operators can make revisions to that procedure you mention?
I prefer the assembly line process where you can have numerous operators
perform those revisions at the same time, over the single operator scenario
inherent to your process. But that doesn't mean that I favor the
compartmentalization of the skills in the operator pool, either.
Making thoughtful use of the XREF'd Base DWGs, you can increase the
potential of your staff also. So that no one gets "stuck" in a position they
will get burnt-out on. All will work on various aspects of the
design/drafting process, so that anyone can be asked to fill in the
necessary assignments needed to complete the project on schedule.
No matter if the schedule was made up by someone who's not had enough
experience to realize that things still take time to accomplish. That view
takes into assumption that the object is to create a quality product,
requiring the least amount of comments from the reviewing agency.
HTH
Don Reichle
"King Of Work-Arounds"
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT3/CD3
IntelP4-2.4
1GB RAM
Intel 64MB
wrote in message news:4845762@discussion.autodesk.com...
Ok, I don't think I'm an experienced enough user to hang with you guys and
I'm not sure I'm typing the terminology correct. Don - why in the world
would you not advocate more than one layout tab per drawing???? Isn't that
the whole point of the later AutoCad releases? You have one main Model Tab
and all your construction drawing sheets rest on their individual Layout tab
so that when you modify any linework to your overall file (in model tab
view) you don't have to do it on ever single sheet. So I have my main file
on my model tab and then layout tab 1 is the cover sheet, layout tab 2 is a
plan and profile, layout tab 3 is a plan and profile, layout tab 4 is the
grading plan and so on. All these layout tabs use viewports to access the
main file via the model tab. Am I not being clear? Why would you not do
this . Do you use xref instead and have every sheet of your construction
drawing set in a whole separate dwg file? Anyway, layoutmerge in express
tools seems to be the command for what I'm asking. My question was really
asking if I'm doing it wrong? It does copy and paste all my layout tabs
into the model tab, but the viewport information is missing. Does this
command ignor viewports? Do you or anyone else know the extents and
capabilities of this command.
Molly
