AutoCAD Land Desktop (Read Only)
4065 Views, 2 Replies
mapbulkfeature
I bring shape files into Autocad 2010. I want to explode the line so that I could change color & line weight. Is there any way for me to handle this mapbulkfeature line.
Thanks for the help in advance.
2 REPLIES 2
In the absence of another suggestion, you could use the ._MAPIMPORT
command to import the geometry, which becomes polylines. I think you
are currently using Data Connect, right?
R.K. McSwain
http://cadpanacea.com
PaisteAbuser
I am also having the same problem.  I have imported the shp files using Map Connect, I am able select very few objects and explode them, wanting to explode multiple objects I get an error message about unable to explode mapbulkfeature.
I have imported the shp files this way because if I use Map>Import>"abc.shp" Cad will crash and not load the entire file.  The files I am working with cover Western Canada and Provincial data, They are enormous files. Not exactly sure what mapbulkfeature is, I am also very new to using shp files. Frustration and anger has set in!
