And, depending on the version, every time you reload the drawing, or
edits drawing setup, it will change the global ltscale back to the
drawing scale you have set.
Karl M. Fuls PLS
Autodesk Discussion Group Facilitator
neilw wrote:
> A good rule of thumb:
> Always leave the linetype scale for individual lines at 1.0 unless
> circumstances require otherwise (i.e. working with a mixture of ISO/Imperial
> linetypes) and global LTSCALE=1.
> In your case, reset all lines to 1 and try setting LTSCALE=1 & PSLTSCALE=1.
> Your linetypes will not display in model space this way, but will show
> properly in PS.
> wrote in message news:5026250@discussion.autodesk.com...
> I have a map With a veiwport scale to 1"=100', i can't get the proper scale
> for dashed lines or center lines on xref's right to scale with the drawing,
> im wondering if there is a command to auto scale so that when im in
> papespace is auto scales 1"=100'. do i have to set the global scale facter
> to something. i tried setting it to 100, but the linetype isn't the correct
> scale, but if i change the linetype property on the line to .01 i see
> dashes, but i need it to remain 1 so that the scale is proper. any help
> please?
