AutoCAD Land Desktop (Read Only)
Line with Text
13 REPLIES 13
Message 1 of 14
CADguy82
297 Views, 13 Replies
Line with Text
I'm trying to show sanitary laterals in a utility plan for a big development. We are using a linetype with SAN embedded within the line: ----SAN----. However, some of these lateral lines are showing the SAN part of the line above it instead of with the line. Any reason why? I thought it might be an elevation factor, so I flattened z values to 0. This problem only occurs on some of them, not all
HELP!!!
13 REPLIES 13
Message 2 of 14
in reply to: CADguy82
stevewalz said the following on 3/7/2006 12:42 PM:
> HELP!!!
Make sure that the style used in the linetype definition does not have a
fixed text height, an obliquing angle, or a width other than 1.0, etc.
What about a new line on that layer? Does it look right?
R.K. McSwain
http://rkmcswain.blogspot.com
Message 3 of 14
Hey Steve;
Does your firm use Linetypes ByLayer or ByEntity? If ByLayer (I hope), try
the following;
In the dwg file where these Lines exist change all of the Sanitary Laterals
to Linetype ByLayer;
Then set the Layer Linetype to this specially made Linetype you mentioned;
Finally do a Regenall, and you should see what you want.
If that's not the case, then (if you're using Linetypes ByLayer) I would
suggest that you remove the San Linetype from use by the Layers. Change it
to Continuous or another type of your choice. Then click OK in the Layer
Properties Manager. Then perform a Purge to rid the dwg of the San Linetype
definition. Then add the "correct" San Linetype (just in case there was an
old Linetype Definition getting in the way of your current work) back to the
dwg file. Finally set the Layers needing the San Linetype back to using it
again, click OK, and Regen.
Do things look correct now?
I learned that the easiest method of getting "consistent" Linetypes of this
nature, was to use a Style set to Zero Height to create them. Then in the
Linetype Definition file, I would specify this Style, and set their Height
through the use of the "s=" parameter. They have always cooperated, and so I
only need the one file for use in consistent Heights - no matter the scale
of the dwg.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce2 Ti 64MB
wrote in message news:5104003@discussion.autodesk.com...
HELP!!!
Message 4 of 14
I recently had this problem and had to go and set the text height to zero for all my linetype styles. I do work behind other people and many things can go wrong.
Message 5 of 14
CADguy82
Alright...I have changed the style that the linetype was using from a True Font to an shx. That did not work. The text style that the linetype is using is already set for 0. I modified the layer to use the continuous linetype. Then I purged out the ---S--- linetype. Reloaded it and changed the sanitary lateral linetype back to the ---S---, but that did not change anything either. Did a regenall and nothing changed. Thanks for all the help you have given so far. It is much appreciated. However, the problem did not go away. Do you guys know of any other possibilities?
Message 6 of 14
Can you post a portion of the file?
HELP!!!
Message 7 of 14
CADguy82
See attached to view what I am talking about
Message 8 of 14
The only thing I didn't see in your reply was "if" you had checked to see
whether any of those entities had been set to ByEntity instead of ByLayer.
You won't see the term ByEntity - so set a QSELECT for Multiple and the San
Linetype, to see if any of the entities are set that way.
If you find any corresponding to that Search, then you will need to set them
to ByLayer - and then go through the scenario one more time to fully
cleanout any previous "faulty" Linetype Definitions.
HTH
Don Reichle
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
wrote in message news:5104182@discussion.autodesk.com...
Message 9 of 14
It's not the San Linetype, it's the S Linetype that you're having this
difficulty with.
Concentrate your efforts along those lines.
HTH
Don Reichle
C3D/LDT/CD/SVY-2K6
Intel P4-3.00GHz
XPPro 32bit SP2
1GB RAM
wrote in message news:5104187@discussion.autodesk.com...
Message 10 of 14
CADguy82
Actually, I am having this problem with SAN, S, SEW, and D linetypes as well
Message 11 of 14
Here's the hard answer:
In your linetype definitions, replace all occurences of text with shapes.
Your problem will go away.
Here is my shape definition for the letter "S"
*21,251,S
4,125,4,80,3,125,3,125,3,80,002,9,(-26,14),(0,0),001,9,(52,-19),(0,0),002,9,(-9,-95),(0,0),001,9,(-34,0),(0,0),002,9,(-26,10)
(0,0),001,9,(-17,19),(0,0),002,9,(43,-29),(0,0),001,9,(-26,10),(0,0),002,9,(-17,19),(0,0),001,002,9,(120,0),(0,0),001
9,(-17,-19),(0,0),002,9,(0,0),001,9,(-26,-10),(0,0),002,9,(35,76),(0,0),001,9,(8,-19),(0,0),002,9,(0,0),001,9,(0,-28)
(0,0),002,9,(-34,66),(0,0),001,9,(17,-9),(0,0),002,9,(0,0),001,9,(9,-10),(0,0),002,9,(-35,124),(0,0),001,9,(-34,0),(0,0)
002,9,(0,0),001,9,(-26,-9),(0,0),002,9,(-17,-39),(0,0),001,9,(9,-19),(0,0),002,9,(8,58),(0,0),001,9,(-17,-20),(0,0),002
9,(0,0),001,9,(0,-19),(0,0),002,9,(9,-19),(0,0),001,9,(8,-9),(0,0),002,9,(0,0),001,9,(17,-10),(0,0),002,9,(69,77),(0,0)
001,9,(-26,9),(0,0),002,9,(43,-29),(0,0),001,9,(-17,20),(0,0),002,9,(-43,-91),(0,0),001,4,80,4,125,4,125,3,80,3,125,0
Doug K
LDT 2005, XP Pro 2002 sp2, P4 2.40GHz, 1 GB RAM, Dual 19" Dell LCD, NVIDIA
GeForce FX 5700LE, Left Handed Kensington Trackball, Happily Married
w/Children
HELP!!!
Message 12 of 14
CADguy82
Any way you have an easy answer as well?
Message 13 of 14
I just had the same problem......had to set height zero to all my styles.
Message 14 of 14
actually, by using expresstools "explode text" "make shape" and "make
linetype" commands, it is not all that difficult.
should only take a few minutes per linetype, once you get the hangofit.
Doug K
w/Children
wrote in message news:5104227@discussion.autodesk.com...
