Hi Brian,
Start the line command from the [Lines/Curves] menu and type .N.
You will be prompted for a Northing, then an Easting etc.
The three toggles .N .G and .P work on most of the commands in the
lines/curves menu as well as the 3D polylines in the Terrain menu.
Laurie Comerford
CADApps
www.cadapps.com.au
"Brian Hailey" wrote in message
news:6B7F2B6482D78F9A79B6E583C7D718A8@in.WebX.maYIadrTaRb...
> Is it possible to draw a line from a known Northing/Easting to another
> Northing/Easting? I've looked under the line menu but I couldn't see
> anything there.
> Thanks,
> Brian
> p.s. I can't use x/y coordinates because I have applied a basepoint/north
> rotation to the drawing.
