AutoCAD Land Desktop (Read Only)
LDT 2009 Description Keys
2 REPLIES 2
RCWisehart
697 Views, 2 Replies
Using recently installed LDT 2009 to work on a project with points and description keys developed in LDT 2007. However, when importing new points the descriptions are not being used. I have Point Labeling turned on in the Point Settings dialog; I have the Current Point Label Set in the Label Settings dialog; and I have description keys turned on for the appropriate Point Label Style in the Label Styles dialog. I even manually renamed my description key file in the project to "DEFAULT" but it still wouldn't read the keys. Any ideas?
2 REPLIES 2
RCWisehart
in reply to: RCWisehart
Actually fixed it. There was left over directory pointer from a prior installation. Deleted it and confirmed other pointers were set to the newer folder and everything works properly now.
RC,
We have this same issue. Can you please tell me how you fixed this. Which directory? What do we need to delete?
Thanks you
riz@jsdinc.com
