Thanks for the dwg file rsmit.
Now that I've been able to add one more Point near the one you were pointing
to, please select it for yourself and access it's Properties for yourself.
You will see that there is no Data such as was artificially attached (I
assume) to the Point you were indicating.
So that leads me to surmise that there is a 3rd-party involved with these
Points. From which you can "likely" - maybe for additional fees (we hope
NOT) - get the information you're desiring.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT/CD-2K4
AMD Athlon 64 X2 Dual 2.01GHz
XPPro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
wrote in message news:5205668@discussion.autodesk.com...
Forgive me I am not a map user or should I say I use it very little.
I'll try to explain the best I can
An AutoCAD point (not an aecc point) has OD (object Data) attached to it.
If selected the Autocad point, within the "Properties" work window, pain,
workspace or palette whatever it is called. On the "Design" tab there is an
area called OD:Data1_CO. this consist of 17 lines, titles are: old sheet
number (oldsht), new sheet number (newsht), old block
number (oldbk), new block number (newblk)..catch on? Data would of course be
the information.
How this information is attached, I have no clue, like I said I am a very
light user.
But I need to get this information to an attributed block.
See attached dwg for example
