I finally just put all of our custom description keys in the default.mdb
file, and let it duplicate from the prototype. I neved did get the
"Survey.mdb" file to work correctly. Sometimes yes, othertimes no, same
project / different project. Just couldn't figure it all out, and didn't
have the time for rigorous testing.
Brent Jorgensen, RLS
The Schemmer Associates
Omaha, NE
"Tim Reed" wrote in message
news:3F8C279D.1110AC24@dot.state.ak.us...
> In the Edit Label Styles dialog, on the point label styles tab, I have my
> "survey" description key specified. In addition, all 3 check boxes are on
for
> "matching on" "substitute full description" and "insert symbol".
> I can't get LDD04 to use my file though. So far the only workaround I've
> found is outlined below where I copy my file as Default.mdb and tell point
> settings to extend the search into the Default file.
> Can anyone duplicate this behavior? Try clearing out the Default.mdb file
and
> use only your custom desckey file. Then insert some points and see if
they
> get filtered or not.
> Mike Norton wrote:
> > Which description key file is specified on the Edit Label Styles dialog?
> > news:3F8AF2F6.236ECB58@dot.state.ak.us...
> > > Win2000, LDD2004
> > > My description keys are not working. I have "active desc keys only"
> > > selected in point label settings, and my description key file name is
> > > selected in "point label styles". However no description translation
is
> > > working using my file. I have used the same methods from ldd1-3
without
> > > problems.
> > > If I copy my description key file and rename it to "Default.mdb" and
> > > check the box for "perform extended default search" in point settings,
> > > then things work. Is this a bug or is there something I'm missing?
