Hi Brooks,
Do you have 2004 and 2005 on the same machine and, if so, did you follow the
pathing instructions in the readme file?
Bud Miller
www.BudCAD.com
"dunganeng" wrote in message
news:29534665.1084364401359.JavaMail.jive@jiveforum1.autodesk.com...
> After upgrading LD 2004 to LD 2005, when I open most of my drawings, it
prompts me to recover the drawing. If I let it continue to open, everything
still works fine. If I tell it to cancel the open, and recover the drawing,
I still get the same error after I open the recovered drawing. We never had
this type of problem until we installed LD 2005. These drawings open and run
fine on machines running LD 2004 with NO LD 2005 installed. However, if I
try to open the file in LD 2004 on a machine that has LD 2005 installed, I
get the same error. It seems that LD 2005 is definitely causing this error.
The subscription support center has been working on this problem for about a
week now, with no results. I was just wondering if anybody else was having
this problem.
> Thanks
> Brooks
