AutoCAD Land Desktop (Read Only)
Layer Isolate and Layer Manager not working
14 REPLIES 14
Message 1 of 15
437 Views, 14 Replies
Hi there, I recently had LDD 2006 installed and it seems to affect the layers commands.
Layer "isolate and Manager" do not work anymore.
They do in Autocad.
I get this error message "bad argument type: lentityp nil".
Same message for both commands.
Any work arounds here?
You don't realize how often you use these until they don't work.
Thanks.
14 REPLIES 14
Message 2 of 15
You got the necessary Service Packs installed along with the 2K6 app
kimvprojects?
http://tinyurl.com/25un8x
HTH if not.
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5569096@discussion.autodesk.com...
layers commands.
They do in Autocad.
Thanks.
Message 3 of 15
We are using LDD 2006, just installed, no-one here has used it yet. I am the first.
HTH?
I clicked on the link and i see quite a few patches, do i need to install them all?
Message 4 of 15
Oh yah, thanks for the reply Don.
Message 5 of 15
I guess that means you were able to figure things out re. the proper items
to choose on that WebPage kimvprojects?
Sorry I didn't get back to your reply before now. 😞
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5569821@discussion.autodesk.com...
Message 6 of 15
Not really, which patch or patches should i download??
Message 7 of 15
Under the Autodesk® Land Desktop 2006 header to the next Back to top on that
WebPage, I would suggest the Service Pack as a "starter" kimvprojects.
But really all of them in that same section will be possibly applicable for
your firm, as none of us are very proficient in knowing the future. ;0)
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5570369@discussion.autodesk.com...
Message 8 of 15
I downloaded the service pack and it said it was not needed as LDD was up to date.
Looking at the other patches I don't think they don't seem address my problem.
Any hints or other suggestions??
Message 9 of 15
OK since the most helpful one has already been installed, I'll need to ask
whether you've also spoken about this issue to your System Manager
kimvprojects?
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5570936@discussion.autodesk.com...
date.
problem.
Message 10 of 15
yes they have been here and can't figure it out.
The commands work fine with Autocad, but not with LDD.
Message 11 of 15
May I ask if there are any other LDT releases on this PC of yours
kimvprojects?
Or is LDT 2K6 the only one?
If there were others prior to 2K6's arrival, how/when were they removed?
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5572010@discussion.autodesk.com...
Message 12 of 15
this is a new machine.
everything has just been loaded.
Message 13 of 15
Could this be related to your issue:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2893360&linkID=9240617
Message 14 of 15
And that will teach me to only use the "useful portion" of the reported
error drw^3!
:-o
Including the "bad argument type: " in the Search of the KB, brought me to
the "No results were found for:" - I know so well. ;0)
Good call!
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5574356@discussion.autodesk.com...
Message 15 of 15
i think you may be on to something here, this is a russian project and some of the characters in translated layers are extended charcters.
but the language was not set to french.
It is set to English- united states.
