AutoCAD Land Desktop (Read Only)
Land Desktop 2008 Repair Fails - Re-Installation Request Disc 2
1 REPLY 1
DavidDavidHieb1627
477 Views, 1 Reply
Somehow my Land Desktop 2008 got corrupted (I think right after a Windows Update), and I ran the Maintenance Repair. Land Desktop 2008 was not functioning at all.  In Options I could not get the profile for Land desktop to function at all.  The Repair failed to fix the problem.  I ran it 3 times.  I next ran the Re-Install.  the Re-Install working and then asked for Disc 2. I only have the original "1 Disc" when I purchased Land Desktop 2008 in 2007.  Help me out here!
David Hieb, PLS
1 REPLY 1
in reply to: DavidDavidHieb1627
I don't now if this will help you at this time, but if you know when this update came in.  Do a restore from your windows help and do a restore prior to this date and see if if fixes your LDD.  You can then research this update to see if it's something you want to let go thru again.  About the second CD, your guess is as good as mine.  You can try to install it on a different machine and see if you get the same message error.  HTH.
