AutoCAD Land Desktop (Read Only)
inserting images
4 REPLIES 4
ebeam
458 Views, 4 Replies
inserting images
I recently had to re-install the "land desktop 2007 civil add" on as none of the menu items were present.
Since adding this portion, when I try to insert images through Map, instead of being given the option to browse for the images all I get is a command line option to type in the name of the image. I have tried setting the path within the Map options in hopes that I would get a list of images to choose from in that location. TAlas this does not work ; I can not even figure out where the program is even trying to search for an image.
any ideas out there? I am guessing this is a system variable that got messed up when IT added the civil tools.
any help would be much appreciated
4 REPLIES 4
in reply to: ebeam
Fildedia = 1
wrote in message news:6356193@discussion.autodesk.com...
ebeam
in reply to: ebeam
thank you Jeff,
when I type that in it tells me it is an unkown command?
ebeam
in reply to: ebeam
yeah, I found it, FILEDIA
thank you soooooo much
Erin
in reply to: ebeam
You're welcome, guess I should try checking the spelling of stuff before I
post, huh? Glad you figured it out.
wrote in message news:6356253@discussion.autodesk.com...
> Erin
