<gtalj> wrote in messagei
href="news:6067946@discussion.autodesk.com">news:6067946@discussion.autodesk.com...
use landdesktop 2007. and the data collector i use to collect shots is a "tds
recon". the files it generates are .job files and .raw files. how do i bring
those points from the data collector to landdesktop 2007. thanks in
advance
advance
<gtalj> wrote in messagethank
href="news:6068539@discussion.autodesk.com">news:6068539@discussion.autodesk.com...
you very much, it worked. i was able to export coordinated through the tds
recon as txt format and then import to ldd. now, and pardon my ignorance, if i
would of to add manually some points to the drawing after the export, how do i
export the points back to the data collector, tds recon? is it the same way i
exported the points but in reverse? thank you in
advance!!!
<gtalj> wrote in messageok
href="news:6069432@discussion.autodesk.com">news:6069432@discussion.autodesk.com...
i got it to work but to the point where i had to remove point group. how do
tou remove point group? is it in ldd?thanks
