AutoCAD Land Desktop
*Ervin Battle
Message 1 of 8 (106 Views)
Importing COGO points?
106 Views, 7 Replies
08-31-2004 02:02 PM
Good evening, I'm writing to find out if someone can give me an idea how to get Land Desktop to read cogo points from a drw file. Thanks for your assistance. ervin
*Laurie Comerford
Message 2 of 8 (106 Views)
Re: Importing COGO points?
08-31-2004 02:17 PM in reply to: *Ervin Battle
Hi Ervin, What is a drw file ? How are cogo points documented in this file ? -- Laurie Comerford CADApps www.cadapps.com.au "Ervin Battle" wrote in message news:4134e765_3@newsprd01... > Good evening, > I'm writing to find out if someone can give me an idea how to get > Land Desktop to read cogo points from a drw file. Thanks for your > assistance. > > ervin > >
*scott mceachron
Message 3 of 8 (106 Views)
08-31-2004 07:43 PM in reply to: *Ervin Battle
Are you sure it's a .drw file? That file type is typically created by Pro Engineer (ProE), a Mechanical product... Unless I'm mistaken ProE can write an AutoCAD r14 or 2000 .dwg file - might give you half a chance of creating point data...the resultant points can be converted to Land Desktop point objects - if ProE IS the program used to create your file. FYI: I've seen ProE used to digitize as-builts of mechanical pieces and parts - bring the point spread into Land Desktop and use the COGO routines to "Best Fit" lines and curves and clean up the data - but it's not the prettiest of processes...right tool for the right job. Thanks for the brain tickle! sm -- scott mceachron total cad systems - dallas "Ervin Battle" wrote in message news:4134e765_3@newsprd01... > Good evening, > I'm writing to find out if someone can give me an idea how to get > Land Desktop to read cogo points from a drw file. Thanks for your > assistance. > > ervin > >
*Ervin Battle
Message 4 of 8 (106 Views)
09-01-2004 06:52 AM in reply to: *Ervin Battle
Wow...i guess you can tell it was the end of the day hahaha. what i meant was a dwg file. I personally am nottoo familiar with the software so if the answer is totedious i completely understand. thanks for you help, ervin
*Russell Dieges
Message 5 of 8 (106 Views)
09-01-2004 07:46 AM in reply to: *Ervin Battle
> get > Land Desktop to read cogo points from a drw [dwg] file. what do you mean by 'read'? Do you mean list, properties, or do you want to export the points to a file? what type of entities are in the drawing? AutoCAD points, Civil Points Objects, or Softdesk Point Blocks? If they are civil point objects, then are they in your project database? What version are you using? Russell
*scott mceachron
Message 6 of 8 (106 Views)
09-01-2004 08:00 AM in reply to: *Ervin Battle
LOL Well hey, if you ever need to work with a ProE drawing, you'll have a head-start! :smileywink: sm -- scott mceachron total cad systems - dallas "Ervin Battle" wrote in message news:4135d423$1_3@newsprd01... > Wow...i guess you can tell it was the end of the day hahaha. what i > meant was a dwg file. I personally am nottoo familiar with the software > so if the answer is totedious i completely understand. > > thanks for you help, > ervin > >
*Ervin Battle
Message 7 of 8 (106 Views)
09-01-2004 12:47 PM in reply to: *Ervin Battle
Thanks for the response.We're using LDD 3 and are trying to export the point information from the dwg to the project point database. They are LDD point objects. Thanks "Russell Dieges" wrote in message news:4135e0a1$1_2@newsprd01... > > > > get > > Land Desktop to read cogo points from a drw [dwg] file. > > what do you mean by 'read'? Do you mean list, properties, or do you want to > export the points to a file? > > what type of entities are in the drawing? AutoCAD points, Civil Points > Objects, or Softdesk Point Blocks? > > If they are civil point objects, then are they in your project database? > > What version are you using? > > > Russell > >
*Laurie Comerford
Message 8 of 8 (106 Views)
09-01-2004 01:02 PM in reply to: *Ervin Battle
Hi, [Points][Check Points][Modify Project] You can see the importance of asking clear questions. Several people wanted to help you but couldn't because they didn't know what you wanted. -- Laurie Comerford CADApps www.cadapps.com.au "Ervin Battle" wrote in message news:4136275f_1@newsprd01... > Thanks for the response.We're using LDD 3 and are trying to > export the point information from the dwg to the project point > database. They are LDD point objects. > > Thanks > > > "Russell Dieges" wrote in message > news:4135e0a1$1_2@newsprd01... > > > > > > > get > > > Land Desktop to read cogo points from a drw [dwg] file. > > > > what do you mean by 'read'? Do you mean list, properties, or do you want > to > > export the points to a file? > > > > what type of entities are in the drawing? AutoCAD points, Civil Points > > Objects, or Softdesk Point Blocks? > > > > If they are civil point objects, then are they in your project database? > > > > What version are you using? > > > > > > Russell > > > > > >
Announcements
Need installation help?
