AutoCAD Land Desktop (Read Only)
Importing 3d LInes into surfaces
1 REPLY 1
jforse
250 Views, 1 Reply
If I have a drawing that is made of all 3d objects, how can I import those objects into a terrain model in Ldd 2007. I have tried using the import 3d lines command, but I get an error that the "surface is not open"
1 REPLY 1
in reply to: jforse
Use Terrain Model Explorer jforse;
Set the Surface you wish to add these items to as Current;
Click the Surface you wish to add the 3D polylines to, and it will expand;
Then right-click the Breaklines category, and it will show you the choices
of Breaklines you can add;
Select Define by Polyline;
Name the 3D polys as suits you;
Select the ones you wish named so;
When you've selected all of that type, then hit the Enter key.
Start from Select Define by Polyline to add more 3D polylines to the
previous group.
I name mine by what they represent:
EOP = Edge of Paving;
GFL = Gutter Flowline;
TFC = Top Face Curb;
BOC = Back of Curb;
etc.
HTH
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5572787@discussion.autodesk.com...
