AutoCAD Land Desktop (Read Only)
Import ElevationContours
4 REPLIES 4
193 Views, 4 Replies
Hi
Does anyone have sample code to import ElevationContour objects into autocad as AeccContour?
Sub contours()
Dim surfName As String
Dim surf As AeccSurface
Dim surfOut As AeccSurfaceOutputs
Dim surfIn As AeccSurfaceInputs
Dim bounds As AeccBoundaries
Dim Bound As AeccBoundary
Dim elevContours As AeccElevationContours
Dim contimport As AeccContour
Dim customobject As AcadObject
surfName = ActiveProject.Surfaces.CurrentSurface
Set surf = AeccApplication.ActiveProject.Surfaces.Item(surfName)
Set surfOut = surf.Outputs
Set surfIn = surf.Inputs
Set elevContours = surf.Outputs.ElevationContours
elevContours.Elevation = 227#
MsgBox "# Contours = " & elevContours.count
'set contimport.coordinates to ElevationContour.Coords
'set contimport.Elevation to ElevationContour.Elevation
'This is where I'm confused
Set customobject = AcadModelSpace.AddCustomObject(???)
End Sub
Tx in advance for assistance
4 REPLIES 4
Hi Marv,
I don't think there are APIs available to do this.
The best method is to use a "Sendcommand" to open the standard Create
Contour dialog box.
The user can then create contours to any desired settings
Laurie Comerford
CADApps
www.cadapps.com.au
"Marv_McD" wrote in message
news:f0d31f8.-1@WebX.maYIadrTaRb...
> Hi
> Sub contours()
> End Sub
Here's a snippet of code I wrote for a routine that
automatically rebuilds the current surface and then spits out contours at
whatever contour interval ( my constant "cont_interval"). I use it for
grading on the fly, almost close to having dynamically updating contours, but I
still have to push a button. Haven't gotten around to adding any Events. This
will give you an idea how to generate contours though.
Fred
For cont = min_contour_elev To max_contour_elev
Step cont_interval
SurfOut.ElevationContours.Elevation =
cont
        x =
SurfOut.ElevationContours.Count
        If
x <> 0
Then
            For j
= 0 To x -
1
cont_coords =
SurfOut.ElevationContours.Item(j).Coordinates
Set draw_cont =
ThisDrawing.ModelSpace.AddCustomObject("AeccDbContour")
draw_cont.Coordinates =
cont_coords
draw_cont.Layer =
"grading-contour"
If cont Mod 5 = 0
Then
draw_cont.Color =
acYellow
Else
draw_cont.Color =
acGreen
End If
Next j
        End
If
    Next cont
My problem was I was setting the custom object to "AcadObject" as opposed to "AecContour"
Thanks for the help
Marv
Hi Fred,
Thanks. It's nice to be demonstrated as wrong. I'll have to go and change
my DTM editing program now.
Laurie Comerford
CADApps
www.cadapps.com.au
"Fred Ernst" wrote in message
news:E079EDD389DCD20ECE4AA1841430208C@in.WebX.maYIadrTaRb...
> Here's a snippet of code I wrote for a routine that automatically rebuilds
the current surface and then spits out contours at whatever contour interval
( my constant "cont_interval"). I use it for grading on the fly, almost
close to having dynamically updating contours, but I still have to push a
button. Haven't gotten around to adding any Events. This will give you an
> Fred
> For cont = min_contour_elev To max_contour_elev Step cont_interval
> SurfOut.ElevationContours.Elevation = cont
> x = SurfOut.ElevationContours.Count
> If x <> 0 Then
> For j = 0 To x - 1
> cont_coords =
> Set draw_cont =
> draw_cont.Coordinates = cont_coords
> draw_cont.Layer = "grading-contour"
> If cont Mod 5 = 0 Then
> draw_cont.Color = acYellow
> Else
> draw_cont.Color = acGreen
> End If
> Next j
> End If
> Next cont
