It's probably a printer driver issue. Start by making sure you've got the
latest ones. With Oce, 1.14 worked, 1.16 didn't (black images), 1.17 worked
but had other problems, 1.18 seems to have it handled (knocking on wood
grain, textured laminate)
wrote in message news:6394626@discussion.autodesk.com...
> I am having a problem printing objects in my drawing which are either tiff
> images or a block created using wipeout. The exterior shape is there but
> the entire inside of it is black rather than showing the images portion of
> it. The block object is created to give a mask effect where it is placed
> in the drawing, you can read the text within it but not anything behind
> it. I hope that I am explaining this correctly. If I print to pdf I do not
> have the issue. any helpt would be appreciated
> Erin
